Electrical warning light
Car  clio 16v
Randomly comes on now and then usually when low on petrol. Then goes into safe mode which is a pisstake. But pull over n pump the throttle a little n play with key fob and it goes away ( without engine on obviously) been to a garage and he suggested the electric throttle module so if had it off and sprayed with contact cleaner but still now and again happens. Any idea?
You done a search? Lots on this, get your fault codes read, possibly throttle pedal or throttle body pumping pedal and playing with the keys makes no difference, simply switching ignition on and off will reset it until it faults again.
yeah had them read.. said electric pedal.. but swapped it over and still getting it.. think its a wiring fault. heard about a over heating coil aswell but dont think that would be the case
