Hi all I now have my engine stripped back to a bare block and so far as is in the bottom end all looks to be in good condition I was planning on replacing all the bottom end bearings and rings and hone the bores possibly new small end and big end bolts I was going to just clean up the engine replace the bent inlet valves fit new water pump and head gasket, cam belt set de phaser pulley. On rebuild I plan to make bracket remove the air con system. I was going to source a 182 manifold to fit when refitting the engine is there any other mods I should consider for the lump while its out of the car So far I only have 400 in the car so there is a few quid to play with but I dont want to go to mad but I do want to run the car on the track any advice greatfully received.
Thanks mike.
Thanks mike.
