Engine coming out....
  R35 GTR
What other jobs should i get done while it's out for a rebuild?:dapprove:
I'm thinking clutch, aux belt, cam belt water pump.
Extras if I have enough cash could be lightened flywheel, conrods.
what about boring out to 2.2 litres?
No point boring out if you've turbo for the money realy.
Ported head and cams if you havn't got them i think you do though.
I'd look at using a different bottem end anaywa though for a better clutch/gearbox.
IIRC boring out the 172/182 engine will only serve to lower the revs at which you reach peak hp
As far as i know, the head and cams are standard.
What about the bottom end though? What options are there for stronger gearbox.
Why is it being rebuilt?
low compression and high compression, plus a cylinder with lots of oil in, i think that's what's up with it.
Dont know what is broken for sure yet.
My rings have gone on number 3 mucho oil in the chamber! Doing stuff to the bottom end is really going to hurt your pocket, usually places that do lightening and balancing will charge one price for rods crank and fly wheel so you may as well get them all done.
Who's setup is it I thought you had a ktec car and they did cams and head work?
Bottom end isn't cheap depend how far you go and how much you DIY. Stronger rods arn't to bad.
Depends how its done it shoulnd't though.
what bottom end mods did it have?
i have..
Forged Rods
Low Comp Pistons
Steel Crank
Dont put woosner (sp) pistons or rods in or you will be re-biulding again soon LOL
i looked into a stroker kit but it seemed pointless
i have..
Forged Rods
Low Comp Pistons
Steel Crank
All i know is it has woosner pistons.....done by bbpt not ktec.
still not got the car back...:dapprove:
good news it's running, but has problems with the map.
Couple more weeks at the most i think.
