engine components
wont help imo, maybe injectors will add a bit if you remap again. But those components are only stronger versions of the originals, designed for use with performance engines.
can any kind of induction affect the output power.hpand torque wise?
you will find those components will be lighter, and you will be able to rev more freely, also should be able to rev to 9g.. with those components..
also dont bother with the injectors untill you have problems with them.
start working on the head with some cams & computer / remap.. far better money spent. and cheaper too,
Id say save for new cams and an omex ecu next mate. Will someone in your country be able to programme an omex though?
The parts you've listed are mainly more durable components for use in cars with a lot more power, turbo'd engines and the like.
turbo injectors and turbo pistons are for a TURBO car, would make your car slower infact (lower comp ratio)
