engine conversion
Car  iceberg 172
Right so my misses has my old 1.2 16v its finished bar the conversion and we have always wanted to convert it so how do I go about it what are the parts needed or is there a place in the west midlands that can do it for me
Cheers guys
It's completely pointless. For the amount of money it would cost you would be better off buying a 172. Plus a converted clio probably costs more to insure than an actual 172
Whys that then
It will cost you more in parts than it would to buy a 172.
If you're determined to do it, buy a complete car (one that's been rear ended maybe?) and you'll need to swap over the following...
Engine, gearbox (and obviously clutch) , driveshafts, shocks and springs, subframe, wishbones, discs, pads and calipers, wiring loom, ECU, UCH, key and all the locks, rear beam (for the rear discs)
I'm not sure about the fuel tank/pump scenario though so you'll need to find out about that too.
Really not worth the hassle tbh mate. You'll need basically everything from a 172/182 to complete the conversion. I.E Engine, gearbox, mounts, subframe, suspension set up, shafts, brakes, ecu, loom ect.... the list goes on! Better off buying a proper Cliosport as you can pick them up cheap as chips these days.
Doesnt need to do the locks to be fair...
Cheers mr potato ill keep my eyes peeled for a rear ended one or if any of the parts are going for a decent price
Will I need the ecu and wiring loom from the same car / engine tho
No. But you will need ECU/UCH as a matching pair so they can talk to each other and work.
You can buy them on here for under £200. But you'll need a complete loom too. Good luck fitting one of those!!
Nah my mates a mechanic and more than happy to do it providing I source the bits and I give him a hand lol
Could you not just buy a 172 / 182 and turn it into your 1.2 ? Its just so pointless due to the 2nd hand prices and even the reward after isn't exactly a battleship compared to today's modern standards.
If it was a vag engine etc then different story
Just buy a 172 in the same colour as your 1.2. Swap the number plates and vin number over and bob's your monk house.
Easiest way, I thought about it many times when I had a few silver ph1's. Would of saved money on insurance admin and tax.
I can't see why the OP shouldn't just do that, easier switching the tax disc and plates than a whole engine. Plus 1.2 insurance and tax prices, win win!
Better off getting a complete car to break down than parts, the wiring on some of the engine loom is different for some non engine parts, ie the heater fan etc.
Full car £900?
