Engine Cover Torx Screw Size??
Car  1.6 ZS + Clio 182 FF
Hi!
I want to get my engine cover off (the one with the 16v 2.0l sticker on) and I have 2 screws left on. I got the others off with a small flat screwdriver but these two are really tight so I need the proper fitting screw head to get them off.
Does anyone know the exact size torx head to get the cover off? I just bought a set of eBay and none of them fit :dapprove:
Thanks!
Get one that's slightly larger for the head, hit it in with a hammer. Then get new bolts :) probably find the head has been rounded off slightly in the past which is why your bits aren't fitting properly! Jon
Got a t-30 and it fits but man... IS IT TIGHT!
I have tried my hardest and the last 2 bolts wont budge :mad: I have tried wedging a tiny flat head screwdriver under the head of the bolt to try and lift it up a bit, I've sprayed WD-40 and it still won't budge!!
I honestly don't know what to do now! I'm considering getting a butane torch to burn the fucker and try and get it off that way. If that fails I will have to get a screw extractor!
Bloody thing eh! I only want to get the *%#$"£@ engine cover off!
Are you using a one of those magnetic screwdriver headed things where the torx slots in the end ?
If yes use a 3/8 or 1/4 ratchet and torx socket
