Engine Dynamics + 421 Catcams
Greeny.
  440i + 182
Greeny.
  440i + 182
What's the spec of the car mate other than the cams?
Just basic stuff tbh:
Ktec induction kit
Homemade matched inlets
De-cat
2.25” Janspeed (Ktec) supersport exhaust
197 Injectors
Got to the point where I’ll need to spend a lot more to get any more power, still tempted by a RS2 inlet mind you, will probably get one next year to hope to get nearer the 200bhp figure.
Greeny.
  440i + 182
Lol I guess turbo is the only way if you want driveability below 5k
Tbh I have no issues with it below 5k, more than driveable, it is what it is I guess. I was looking at going the turbo route but couldn’t justify the cost. I do like the thought of keeping the lump n/a but saying that turbo is definitely the way to go to get decent figures as you would expect really but it would cost me over 3 times the amount a set of cams and a remap did.
  Clio 182
I have got the sm inlet with 438 cams and made 199.9bhp. Torque peaks at 3500rpm. If you can get a rs2 well worth it.
leeds2592
  Bean 182 + E70 X5
That's a great figure, would the cost of an RS2 actually be worth it for, what will be, only a couple more bhp?
leeds2592
  Bean 182 + E70 X5
Do cat cams require special timing? If not, seems a bit pointless going for 197 cams over 421s or 438s, other than them being a bit cheaper initially but after getting the special timing, it'd would work out the same?
JamesBryan
Cat Cams run standard timing or custom (with the non VVT version).
Timing the 197 cams in won't cost anymore than what it would to time them to standard.
Fletcher
They need special timing yes.
A lad i know with a 172 cup has 197 cams with a standard inlet and it made 195bhp and 177ftlbs at EFI.
Good figures!
I would also take my 172 to EFI for mapping.
Having group N timing doesn’t really cost any more money. My understanding is you just need the group N timing tool when you change the cambelt.
leeds2592
  Bean 182 + E70 X5
Good figures!
Thanks for the replies guys, I've never looked into cams so don't know anything about them really so just asking for my own learning :)
Greeny.
  440i + 182
End of the day all power figures are irreverent to a certain degree, there are so many factors at play.
Interesting that catcams would release two different sets of cams that are ultimately the same spec though.
JamesBryan
The 438's are Ktec's custom ones that are made for them by Cat Cams.
This is the specs for both, although they don't list the lift at tdc specs for the 438's
5502421 | 276 / 268° | 240 / 231° | 11.25 / 10.25mm | 0.65 / 2.25mm
5502438 | 276 / 268 | 240 / 231 | 11.25 / 10.25 mm
