Engine Fault Codes Readout.
Car  Westy. MX5
As I have had a flashing Emissions light blinking intermitantly and what seems to be a misfire on idle only recently, I thought I'll have scan and found the following------
3504 Fuel Evaporation regen. valve malfunction open cct./short cct.
3506 Fuel Evaporation regen. valve malfunction.
5517 Brake Pedal switch Plausibility.
5516 Brake Pedal switch malfunction.
6019 Combustion failure detected misfiring with CAT damage.
Now, 3504 & 3506 I can put down to the Carbon Canister being removed but the valve retained.
The other codes I'm not sure about as the brake lights work OK.
I've since replaced the coil & spark plugs and it is still misfiring on idle.
Any ideas?
