Engine Fault codes
hi all....was wondering if anybody can help me tell me what these to faults are and what affects them
1. wheel speed sensor signal rear left
2. Wheel speed sensor circuit front right
thanks if you can help
Wayne
ave just changed th front abs rings th other day
and th back sensor was changed a while back but it was a long cable but had the right plug on it
thanks for your sugggestion
perhaps just a stored fault that never got erased check all you abs rings r fitted correct and not broken and that all abs sensors r connected correctly erase all the faults and try from there
