www.renparts.co.uk
In the laguna 1.6 (1998) is it a k4m engine that fits in the clio? and what gearbox is it?
thanks
josh
thanks
josh
does the laguna 1.6 16v gearbox fit to laguna 2.0 16v engine?( K4M to F4R )
Yep but why.
CHeck about speedo sensors though you might need a box with sensor so get the right one if the box has the sensor its not an issue if it does or dones't but if you get a box which does't have it your car needs wiring mods to make it work otherwise.
So is the gearbox from a Laguna 1 a JB3 or not?
