Engine Management Light
It will come and go, dont worry about it. Stick your normal cat back on and when it goes out it will not come on again unless something is wrong.:)
Come on when i fitted decat and now fitted std cat and reset it on the test mode but wont go out ideas??
The dashboard trick deons't rest the light you need a garagew ith a computer to clear the fault or least the car after a few restarts it will fix itself.
