Undertray off.
Support sump on a block of wood (with a trolley jack underneath it!).
Jack up slightly to relieve weight on mount.
Mark on chassis where mount is located.
Undo mount to chassis bolts.
Undo central bolt.
Jack up to make removal of mount easier.
Replace mount and reverse above procedure.
From memory, I think that's all thats involved. Don't know if the procedure is made more difficult by having A/C because I have a Cup?
If your careful you can do it without undoing the undertray, the lifting plate on the trolley jack will fit easily through the sump plug acess hole on the under tray... i've always left mine in place.
^^ Its only 4 extra 10mm bolts lol Far better to take it off and use a bit of wood between the jack and the sump. Everyone has there own way of doing things suppose
