engine mount
Car  Fiesta Zetec
On my drivers side mount the solid rubber cone shaped part seems to have a very small hole right at the top near the joint/ nut, is this damaged/ starting to fail as there was also a small amount of brown oily fluid on it too
any advice would be great
i think it's busted..
You have a 1.4 so must have a little less stress on the mounts than a 172/182, but i'll be changing all my mounts this week for the SECOND time in 65k.
The mounts are no good/do'nt last that long from Reno
the leaky bit you were talking about ; Two weeks ago a mechanic at Renault told me about this, they change the part when seeing this. Although the Sport models have solid ones, other models have em filled with oil ? Something in that matter
ok, is it an expensive job??
