Engine oil filter change question!!!
Car  Nothing at the mo :(
hey all, i know how to change the oil and everything, even taking of the fuel guard rail
But from looking at it last night there are alot of cables below the oil filter. when i unscrew it wont it go everywhere? or is there a better way to take it of?
Tilt the filter back, as you lift it away. There's a fair bit still in there... or there was in mine today.
hmm ok, il whack a old towel and a bit of tissue underneath it, il try and unscrew it as fast as i can and tilt it back
not really. i was just asking what people use to catch the oil. someone else i spoke to has brought a small lil tub to put under the filter
urrmmm
laters treacle
I just let it run down (whilst extracting the filter as quickly as possible once undone) leave it to drain for a few minutes, then give it all a blow off with brake cleaner, into the drain pan
there should be minimal spillage, any concerns i'l change it for u for £24.80! Alot cheaper than alot of the ''specialists'' ;)
Come to me Ile do it for £25 as you had a cambelt done last month will be with genuine oil filter and evo sxr oil.
Good to you aint I ;)
Oh and Danny!!!
As regarding to mikes post
There service is 2nd to none! Ive never dealth with people that are so honest and hard working as the guys at rentech :) Like i said on other posts il be going there from now on, Even to just fit my next exhaust when i get it. even though its a hour drive :)
