Engine rebuild not going as it should
As you said on an earlier message it's possible the cam lobes have spun on the cam causing the valves to be pushed out too far.
I have measured the extension of the valves from the top of the Head and they are measuring 7mm on the exhaust and 6mm on the inlet, by my reaconing they need to be 1.5mm- 2mm other wise they will smash in to the pistons?
