clio mk2 storia 1.2
hi im about swapping a megane K4m engine 1.6 frmo 2003 into my clio storia 2007 with 1.2 engine
i'v read thats everythins is bolt on, and a car mechanic experienced guy and done 3 engine swaps in peugeots.
what aabout the connectors , the hole engine loom after ecu and all that goes to the relay box the same relay box as in my clio from what i v understood, but then? is there more connetors firther to the dash=? is has to be, like engine temp, oil temp, all that, is that connetor the same? or i need to solder cables? i v read ive dont have to.
the gearbox should work with my original hubs ive read and shafts. even the downpipe will fit?
the uch i need change to the donors car i know likle the key,
what exaktly need to be change? and what about the trottle cable does it need be electronic like on my storia , what if its cable?
