engine transplant
just wondering what engines i could directly transplant into a 1998 clio mk1 phase 2? would a mk1 phase 2 1.8 engine fit onto the same engine mounts or will i need to alter them?
so all i need is the engine and mounts. will i need the 1.8 gearbox aswell? what else would i need?
Engine, gearbox, mounts, wiring loom, ECU, radiator, fuel pump idealy and fuel tank also PAS rack needs to be sorted the Valver has one so either find one for your car (if you've not one fitted) or remove the PAS pump from the engine.
Idealy you'd want the dahboard and the interiaer dash looms plus the dial for the dash for oil pressure etc.
