Engine whine when moving between idle and 2000ish revs
My car has developed a whining sound that happens when travelling at low speeds in the rev range between idle to approx 2000.
It happens permanently and not a one off.
no noises on idle
  clio 182 trophy
The engines do that in the 1*2. I don't know if it is the same for the twingo engine but it likely is. Someone in the know will let you know soon. How noticeable is it?
Sorry it's a twingo rs, and apart from sounding like a tractor on idle which is normal, the engine and gearbox have been perfect with no noises. Seems quite central the sound in the engine bay.
Renault replaced the waterpump, cambelt, aux etc last year
MicKPM
ClioSport Trader
  Clio16v/Zoe Z.E.50
I honestly do not know if these are ePAS or Hydraulic. I suspect a PAS issue though if it's hydraulic
