Ive wired my epas ecu up as per oem so it sees rpm and vehicle speed. Works great without the rack sensor and adjusts steering feel with speed. Ive not even looked at the sensor on rack, as i i dont have it. Cant do too much, ive had the epas ecu up on diagnostics and it still registers the torque applied.The sensor located on the rack is a torque sensor. Not needed as the epas conversion utilises the rotation resistance knob to achieve the same operation.
Ehpas is the best approach as hpas feels great, i believe the cup racers used the same. I might follow suit if i can find a suitable location to fit a pump.I switched over to EHPAS now Jon , works really well I find .
But that’s a great shout on wiring it up to the ecu .
Hi, interested in going down this route. Do you have any details of the wiring diagram for wiring in the epas ecu to a stand alone ecu?Ive wired my epas ecu up as per oem so it sees rpm and vehicle speed. Works great without the rack sensor and adjusts steering feel with speed. Ive not even looked at the sensor on rack, as i i dont have it. Cant do too much, ive had the epas ecu up on diagnostics and it still registers the torque applied.
Bin the rotary control and get the epas ecu wired up to your standalone ecu for rpm mate. Works mega, assistance is so much better on low speed.
All you need is vehicle speed from the stereo wiring of all places, and rpm from your standalone ecu.Hi, interested in going down this route. Do you have any details of the wiring diagram for wiring in the epas ecu to a stand alone ecu?
Cheers,
Colin
Thanks for your reply and assistance.All you need is vehicle speed from the stereo wiring of all places, and rpm from your standalone ecu.
Theres a load of info on this post. https://cliosport.net/threads/epas-fault-help.841005/
