Car is my 172 rep DCi. Fitted with what I was told is early ph2 172 complete front end setup (subframe, wishbones, shocks, hubs etc etc), I fitted all new balljoints and poly bushes.
But, the problem. I noticed when fitting the shocks up, there's a huge amount of movement in the lower two mounting bolts, mostly in the hub holes.
Pushed right in, I get 3degrees neg camber, and pulled right about about zero.
I'm pretty sure this isn't normal!
Anybody come across this before?
