Exhaust fitting, 172
Car  RenaultSport clio 172 mk2
I have recently ordered a sportex exhaust for my 172 after the back box on connection corroded and fell off. I had to cut throught the little rubber attachments on the bracket to remove the back box.
I have the car booked in a garage on hursday to install the new exhaust, will they have rubber attachments? Sportex say it is a standard fitting but i believe renault supply them with an aluminium bracket???
You need to buy one from Renault mate, about £20~
Your right in saying the rubber mount is part of the aluminium casting.
I asked Sportex directly if I needed this from Renault, he seemed to think a standard rubber mount from a garage would be ok?
Oh yes..typical Renault eh
actually, yes you can just use a normal rubber!
using the existing aluminum ali bracket you can wedge a normal rubber into it
ask ant, he did it
