Exhaust gasket spring kit
  Ph1
Gasket / Fitting kit between manifold and cat:
Are these kits universal through out the Clio range? or are they only used on the 172 / 182's models ?
Car you buy them from a Motor factors type store ?
How tight should you fasten the bolt? Right up to as far as the threads go? or leave a bit of slack?
Mines blowing bad, but the inner mesh gasket is spot on with no tares or holes! :S
Can only assume its compressed somehow or the exhaust moves back under load.
The kits only about 6 months old too :(
