Extra part with new rear wheel bearing kit?
Car  R35 GTR
I have removed the rear disc and bearing assembly.
inside my new wheel bearing pack there is the circlip, nut and bearing which I know should be there.
But there is a rubber washer/boot thingy in the new pack too. There isnt any rubber bit visible on the disc and bearing assembly.
where does this rubber bit go? I am 100% it is the correct bearing kit as i got it from k-tec.
Another few questions : what torque do i need for the two bolts that hold the pad holder and the big nut in the centre of the disc? And how much force is too much for pushing the bearing out on a press?
cheers guys.:)
big 30mm nut is 175Nm and caliper ones are 60Nm
Not sure what the rubber thing is, i got the renault discs as a kit so it was all assembled
the non oe bearings i have bought in the past come with a little plastic/rubber protection thing that you throw away, could be this. Got a pic Dave?
Not a good pic, but this is probably the same bit your are talking about.
