F4R Cylinder Head????
Car  RS6+ & 40d MSport X5
How much would 1 of these be worth with bent valves? Done 50k afaik..
Came off a cambelt failure!
Got the cover & oil cap too!
Gaz
whack some valves in it and double its value imo.
easy enough to do diy cant really get it wrong.
I'll be putting a for sale thread up for £30+p&p
If it doesnt sell by sunday it will be scrapped!
sorry to but in but i have whole engine, bottom end fine but top end has 1 snapped valve and more than likely a scored bore. the cam belt has been taken off but has all the tensioners ect. I have taken the cams and dephaser off
How much do you think it is worth and does any1 want to buy.
thanks alot james
thanks alot james
i'll give you £50 for it.
thanks alot james
Shove it on ebay. Bottom ends worth a tonne alone
thanks alot james
Is your engine out of the car and at a garage in Morpeth by any chance?
not being picky but if it has a scored bore then the bottom's end not fine...worth scrap value unless its stripped and inspected...
