F4R Cylinder Head????
  RS6+ & 40d MSport X5
How much would 1 of these be worth with bent valves? Done 50k afaik..
Came off a cambelt failure!
Got the cover & oil cap too!
Gaz
  LY 182
whack some valves in it and double its value imo.
easy enough to do diy cant really get it wrong.
I'll be putting a for sale thread up for £30+p&p
If it doesnt sell by sunday it will be scrapped!
  Amarok
sorry to but in but i have whole engine, bottom end fine but top end has 1 snapped valve and more than likely a scored bore. the cam belt has been taken off but has all the tensioners ect. I have taken the cams and dephaser off
How much do you think it is worth and does any1 want to buy.
thanks alot james
  2005 Nissan Navara
thanks alot james
i'll give you £50 for it.
  Ph1
thanks alot james
Shove it on ebay. Bottom ends worth a tonne alone
  Ph2 172
thanks alot james
Is your engine out of the car and at a garage in Morpeth by any chance?
not being picky but if it has a scored bore then the bottom's end not fine...worth scrap value unless its stripped and inspected...
