F4R Main Studs
mikekean
Car  996 C4S, 135i, E30x2
Hi Guys,
How common is it to replace the main studs when rebuilding an F4R? will be carrying out a basic rebuild on my motor and would rather not spend the extra £100+ on studs if it's not necessary, its a bog stock engine so wont be over stressed.
Mark, any insight on the conrod bolts too? 70-80 quid on 8 ARP bolts!! - are they that special?
Also I think the OP was referring to the head studs, although good to know about the main bearing bolts ;)
Also I think the OP was referring to the head studs, although good to know about the main bearing bolts :wink:
Yeah. Use arp! Lol! That's as much insight into that as I'm ever going to have.
I'm on standard head bolts as well. Good enough for R3 maxi - good enough for me. :up:
Here some compare of main studs :wink:
