FAO All Eagle F1 Users
What pressures do you run at?
I have recently fitted a set and have them at standard pressures as quoted in the handbook but they seem very hard.
They dont feel that hard.....but I have noticed the front end starts to break awy quite a bit easier than when I had the Contis on.
Tought it might that I had them pumped up too much???
  clio 172 MKII
ive put them on mine after changing from Contis too - same as - ive got them at 29 on the front
  Ph1
29 PSI thats a bit low that. I worked it out to be 33 front and 31 rear.
  BMW 320d Sport
Ive always run mine at least 34psi cos I dont like the lack of high speed stability at lower pressures. Theyve got a square enough cross section to not go bald in the middle at these kind of pressures as long as youre running a 40 profile or less.
