I have considered an addon box that is exactly that m8.
I agree, knobs are easy lol !!.
Maybe a five position switch for the gear and individual knobs for the parameters. hmmmmm.. although I must confess the use of an lcd display and up down buttons is easier to integrate.. unless I use another PIC Micro as an Analogue to Digital converter to use knobs and pots...
yep, that sounds like a winner... I will let you have a prorotype no probs.. on one condition lol... it is eperimental or (MENTAL !).. and what you do with it or have to replace is your problem hee hee..
It should work fine.. he said.. trying to catch the falling piston and half con-rod. !!!
The nice thing is you can set it up on the bench and test it, and if you dont like something, alter it.. not just the user side.. but the main code, the WAY it works... the best mounting BOX is an old ecu case, the ford EEC IV units are cheap like chips and have a built in connector and rfi shielding too.. BONUS dood !.
Dont bother with the TC just yet, if this works, then it will do the job... it may even be possible to use without NOS, in fact, it WOULD be possible... its wheter my programming skills are up to it lol.
Jonathon has kindly offered to assist in the finer points of PIC programming so thats a great start... along with your genuinely valuable input, it should at least be a great starting design. It would be nice if Nick offered an input too.
Joe.
