*** FAO Clifford experts
  "Navy" N17 TWO
I have Clifford concept 650 installed with prox sensor/remote headlights
If alarm is in-active for a certain period I cannot turn my headlights on by remote. Can this period be tweaked?
If the proximity sensor gives a "warning shot", should it somehow let you know when you disarm the alarm?
Is the auto-window closure feature any good?
Nafoff
i had the exterior proximety on my rt and it never let me know when i disarmed the car, the only warning was the three cherps when someone/something got close to it
If your alarm is set off it will give you 3 chirps to tell you when you de-arm it. If you then look at the blue flashing light inside it will flash in sequences of anything from 1 flash to 10 flashes (a long pause indicates the end of the flashes) to tell you why it went off. Theres a list in the handbook telling what each one is.
If you have a Cliffnet Data Cable and the Cliffnet Wizard programme you can tweak most things. Headlights, Auto door lock (and timing of) etc...
  "Navy" N17 TWO
Freebone - its a great alarm isnt it?
thanks covkid - dont have the facility to plug anything in - installer tweaks it usually. only have it 3 weeks so still adjusting to it.
getting used to the blackjax is a little tricky sometimes - get in and forget it - drive 200yds down the road - chirp chirp! :devilish:
