fao everyone with tapping 182's..
if anyone has a tapping sound on idle (only when warm) and builds up after about a minute of being on idle.
speeds up with revs till about 1.7k then goes.
give it a good rev and it dissapears for all of 10 seconds or so where it starts to build up again and cause sever anger!
can only seem to hear it when sat inside the car too.
if this is exactly what yours does.. can you add to the list?? gonna be ringing renault UK about this as my car has been into the stealers about 3 times about it with no luck.
*one time they told me it was normal
*next time i took it in with the charcoal cannister post by TVO, they said they couldnt hear it when i showed them it. then said when i collected it that they had sound deadened it to fix it.
*then its no different so next time its in i mention it again, to be told that renault uk wont authorise repairs if its not on their system as beign common fault.
so could do with some numbers of who its happening to for when i speak to renault uk customer care..
1. Guy - 04 182
2.
im not sure dink.. i ve heard the VVT is only used on idling
so maybe it 'could' be something to do with that??
my 1.6 does this i think although only while crawling along in traffic
ive just been pretending i cant hear it......... although its happened since new so assumed it was normal
i can hear tapping from 182 (04 - 22000miles)
I've had for nearly a year! Just as Guys but my tapping can be heard from the outside now too...
Same answers from Reno!
My 52 plate 172 does exactly this. Renault dealers said they couldn't hear anything unusual when I took it in to them, so I'm just ignoring it for now.
get them to check the injectors, most injectors on the clio sport range are generally very noisey and give a 'hydraulic tappet' kind of sound, which can worry some drivers! its perfectly normal, not everyones problem will be down to this, but im sure a good few are. my 172 cup sounds like that and at first it set off alarm bells in my head! but after speaking to a few renault techies and high tech mechanics they gave it a once over and put my mind at ease.
Dave3141 said:
mine sort of whistles when pressing throttle. :S
I get tapping too.
:D Mine does that with the Air con on.
Not sure on the noise though, Sometimes I think its making a noise but then I think I am paranoid because its french :dapprove:
