FAO People Running ..............
MarcB
  Vw Golf
People who are running 4 Pot Brembos with the 300mm discs what discs are you running ?
I know you can get standard Renault Scenic 300mm discs / Brembo's but looking for something a little better along the lines of G hooks or something.
Clearly cant run anything from a MK3 197 / 200 as they are 5 stud discs / wheels and the Clio 1*2 is only 4 Stud discs / wheels.
I have seen these but once again they are not 300mm and only standard discs.
Clio_fool
MarcB
  Vw Golf
I’m not really looking to spend £400 on a pair of front discs for a car that does less than 100miles a year.
I have already contacted Godspeed so will wait for there reply.
deanoE30M3
You'll need new caliper brackets for those discs as the offset is different. Not exactly a good value solution imo.
I saw them the while ago thought they’d might be of use not the cheapest no, but I also didn’t realise you’d need new brackets in all fairness!
Clio_fool
Not exactly crystal clear, maybe that they are saying other brackets aren't the same offset as theirs? From pms listing for the discs:
MarcB
  Vw Golf
I called Godspeed today and spoke to them direct, The only thing they knew about the 300mm upgrade was the fact the Pure approached them for a Bell and Rotor disc for it other than that they knew nothing about the standard 300mm discs.
I explained my case and the confirmed they can do standard 300mm discs (4 Stud) to fit the Brembo upgrade at a fraction of the cost compared to the £400 price tag of the the Bells & Rotors.
It honestly would not surprise me if GodSpeed start to sell G hook 300mm discs for the brembo upgrade.
