FAO People with Volvo turbo'd clios. Wiring issues. Malice/Mole etc
  Rb 182
Wiring, seems that you have to use half the volvo loom and half the clio original loom. And swap sensors between the blocks.
  Rb 182
Just had a thought
if i used the clio Rsi loom that i have (rather than my standard Rt loom)
Most of the sensor should (maybe????) fit??
Ideas?
I'm here too!
The Volvo uses a MAF sensor and th eclio uses a map, so you sadly just can't just use the rsi loom.
the volvo loom modified is what you want.
You need to use the ren oil and temp senders to get the dash working correctly. The rest stay volvo but you need to splivce the wires to the clios brown plug on the nearside wing. Ecu is in a different place but thats not a big problem.
Djw John
Scotland - South
Ok cool. Another problem was that the volvo loom didnt seem to have all the sensors on it which confused us as there were some extra sensors and some missing :S Do we just use the Clio sensors for teh missing ones?
was the volvo loom chopped?
Which sensors are you missing.
Basically
REN lump
ecu senders
AIT,
CTS,
TDC,
Lambda,
TPS,
MAP,
road speed (this is taken from the dash and goes via loom alone on the smaller grey plug beside the big brown one to the dash)
ecu outputs
ignition module,
injectors,
charcoal canister solenoid,
icv
fuel pump switch wire (to relay)
dash sender gear
ignition module,
temp gauge,
water light'
oil pressure light,
alt light (brown plug on alt)
oil level
Volvo
all the above but add MAF
oil temp,
oil pressure
basically.
  Rb 182
Hmmmm the loom i have is not chopped, ill need to look into this or get some one in to sort it. I wnat it running this weekend!
  S2000
about time ;) Nice to see your that close to getting it sorted.
btw, were you in jjb at hermiston gate today dave? in eviljohns car? ;)
  Rb 182
Engine will be about 160 at the fly (maybe slightly more) SHOULD BE OK.
Yes i was, looking to get some new footy boots. Thats my loan car for a few weeks.
cheers John btw ^^
  S2000
lol, thought so. I work there and just caught a glimpse of you as you were going out the door but wasn't totally sure it was you - then saw eviljohns car go past the front a minute later so knew it probably was, lol.
  S2000
haha, I'm not going to go into that much. Basically the 1.4 isn't insured and the 16v keeps going wrong. I had my dads mondeo with me instead.
