172 phII
Right, the time to put performance camshafts into mine F4R 732 has come.
I need a recommendation which ones to take. The choice is between catcams ( 421, 428 ) and schricks.
So far my first pick (best buy) are 428 catcams, is there a better option?
What kind of power band I can expect for each of those and what are possible gain with this setup?
Car is running on stock internals ( engine has 120 000 km), performance mod list include:
port matched intake
CAI
Teflon gasket
182 port matched exhaust manifold
custom exhaust with de-cat
ECU side will be sorted by Henk, I will also be using a wideband O2 sensor for logging (custom map).
Car is used as a daily driver, but is frequently attending track days and drag races. Ideally I would put rev limiter 7800 rpm at the highest.
Any useful input is more then welcome
port matched intake
CAI
Teflon gasket
