fast road geometry setup
Car  RB 182 cup
well due to have a new job with a full geometry machine i want to set up the clio
now im after some spec to try both front and rear, toe camber etc
will be sticking it on to see where its at, then order shims etc to correct
i do drive it fairly hard and do do the odd track day when i have spare funds so any help please
+1 on rear shims, what differencnce is made by having them fitted? sos for hijacking thread
I've been recommended to set mine up with 2-3 degrees of negative camber & some toe in at the rear for road use & hillclimbing. Not had it done yet as I'm still unsure if this is correct or not?
I have rear toe OUT which helps turn in but as Fred says its whatever set up your happy with.
Also had a rear ARB which made it all to tail happy so removed it.
