few problems just had my car itb'd
Status
Not open for further replies.
We were never quick tot ake the money, and we did do a before run and it was a messy curve.
As a tuner, we are tasked with a job, which we undertake. Nick came down, test drove the car and took it away, I asked if he was happy. He then brought it back as then decided he wasnt happy, and I have offered to get to the bottom of it.
Other tuners would of said: Oh your the guy thats paid already, see ya later...
Also, by 100k car cars he doesent mean lambos, he means the race adn track cars we looks after that are worth 100k, but experienced racing teams that trust us for our tuning work. And that does say something for a company.
My aim is to get the car running spot on, and to look for advice on here from people, like Danny, who are in the know. The cam timing was out by about 30*, have a lookm previous for pics.
If we have been given a dead lump to tune, I'll tune it. If you want me to strip it down, inspect it and certify that this engine is ready to be tuned, I'll do that, but it wont be for free.
We have seen 155bhp from other clios (like Andy Knights circuit car 172 that we tune) and then with ECU it made just over 180bhp. (everythign else OEM)
If people like Danny (who is respeceted on here) and knows clios inside and out scratches his head, where does that leave us?
The car is being done but unfortunately we do have comitments and support contacts for race teams that must be adhered to. When Nick wants to coem down at 8pm and take bits off I'm there. Find somewhere else that accomadates all hours of the day to get things sorted....
Typical forums.
Confirm basics:
-leakdown test
-confirm lift@tdc (don't assume it's correct for the cams just cos the Renault timing markers have been verified--cams could be fitted wrong way round---it happens)?
-base ignition angle correct?
-fuel pressure correct?
-ecu/injectors/coil functioning correct
-----I did suggest this but assured by Danny and others that the stock timing marks are spot on for these cams. Its not how usually do it for Kents etc on Zetecs but thats Zetecs
---Will check again but yes, using my standard clio basemap
Yep
Yep
But how far do you go mate?
I mean he wanted itb's fitting, should a car have its timing checked, leak down test etc before any work is carried out?
He informed them of the spec, as far as he was aware the car was running well, it came in low on power and now they are trying to fix the problem FOC, i know it has taken a little while which is a bit of a pain, but as far as i can see its just an unfortunate situation, with no one person to blame
Exaclty my point.
How far can we go? Should we check that people havent ran fuel lines through the backbox? Or the hubnuts are tight before we map it? Tghe list could be endless. Yes, I can confirm an engines health, but I would fully strip it and blueprint it to be 100%, and that isnt 'cheap'
Matt
  2005 Nissan Navara
I personally think its a shagged motor, % gain is pretty much correct for the itb work, its the starting figure which is low (and brings the corresponding modified figure down).
Leakdown test the fucker...bet its leaking like a b**ch past the valves.
  williams and trophy
my ears are burning... lol
TBH, get your money back, get the cam timing re-checked again and take it elsewhere in my opinion. Lets be real, it should not take this long regardless of problems and you are not paying them to learn about Clios.
errrrr pot calling kettle black ;) lol
how many have you paid to practise??
still....least youve seen sense now.
Sorry matt I thought I read it had lost power once cam timing was corrected, edited my post.
it did lose power when the cam timing was done !!! lost 50bhp , it was 155bhp when it first went in , 188 when it came out of there running sh1t, now it is 130bhp after having the cam timing done
Matt surely you can understand his frustration? He is a 172 thats had thousands spent on it tuning the engine for it to currently be running not much more power than a 1.6! infact there are 1.6s on here with MORE power!!
Mine was 158bhp, and went to 204bhp
So the low starting thing doesnt sound correct, unless its a bad egg?
Oh and birchdown have been there well past closing for me, so other people do do it :) Its great that you do as well! :)
the way i see it is the car went in there running fine to me , other wise it wouldnt of been dropped of there in the first place , as i was spending £2100 on bodies so wouldn't skimp out on getting a problem sorted in the first place and as the car was going to be purely a track car i definately wouldnt of dropped it of there if i knew the cam timing was out , there is a renault specialist near me who could of done it for cheap , 3 months on the car is still running sh1t and still stuck at m tech , dont get me wrong matt seems like a top lad and has definately tried his best to sort the car , i think he just has way to much work booked in and my car keeps sitting there at the back of a quew as he needs to get the unpaid job's done before mine !!! you can understand my frustration matt as im sure you would be the same if you were in my boots , :(
Nick, no I do understand, like I said will get it 'done' for friday. I'm going to pop it back on the dyno tomorrow and hopefully we can do some tests and get it either finished and good or at least diagnosed.
Cheers :)
  53 Clio's & counting
Glad to hear things are progressing guys, Matt, pop back on tomorrow and let us know what you find out, as Stan has said a leak down test is most def needed, it wouldnt suprise me if its nicked a valve and its not seating properly
  lift number 1 @ btm
But would it still show good even compression then?
  ITB'd MK1
The compression is too good for it to be an engine weakness. I've told Matt what i believe it to be after doing some comparisons, have to see what he comes up with
  HBT 172 Cup
The way i see it after reading between all this squabling
Car went in with 155bhp.
Car fitted with bodies and mapped with incorrect timing makes 184bhp.
Cam timing correct, but mapping not changed to suit correct timing, 130bhp.
Is this not just a simple case of a remap on the correct timing? whats the big problem?
  Track 172cup
it's good to see some of the other companies/tuners etc.. helping out another company tbh
also as said before matt is definitely going one step further to try and rectify the issues (just like a few of the other companies on here would do aswell) so fair play
hope you get it all sorted on friday, for both of your sakes and sanity ;)
  2005 Nissan Navara
Well practically speaking power doesnt just dissapear does it.
Assuming the dyno is reading as it should, and assuming the fuel and ignition system is functioning properly, then its (basically) down to cylinder sealing, volume of air per cylinder, fuelling value and ignition advance value. Obviously there can be one or more contributary to each of these.
Volume of air can be tested with a flow meter whilst doing a power run. If this is low then you'd want to be checking lift at tdc, valve lift, throttle angle, basically anything and everything that contributes to cylinder filling, and AS crucially thats its the same per cylinder.
You can also do a blow-by test whilst doing a power run, to show loss through the rings when under full load/power conditions.
Fuelling is obvious as that will be logged on the dyno, and is specific to the above.
Ignititon lead, you can check ACTUAL advance manually whilst doing a power run to confirm it is what it the ecu is saying it is (I cant remember what ecu it was, but a friend of mine had a similar issue, it turned out to be the crank angle sensor was wired the wrong way round, and since the signal was "upside down" at a certain rpm, say 3500rpm, the ignition advance would just revert to a static 15degs!)
Oh, the exhaust isnt blocked is it?!
  Golf GT & A4 Avant
any updates matt ???
Would it not be better to pick up the phone and ask him personally instead of waiting for him to come on line, especially if you're after your car back farily soonish.
Just a thought, and not meaning to step on anyones toes in anyway. but after all is cured and it turns out to be down to a previous fault and nothing to do with the ITB convesion, will it still be FOC? Bl**dy good service if it is in my books.
Gaz_
  Extreme mode
Very strange this. Why doesn't nick just use a phone, like a man?
didnt have chance today as i was flat out, i always ring them to see how its getting on and usually they havent had chance to look at it ,
People need to stop spamming this thread as well , and stating the obvious of phoning them , im not stupid and do ring them all the time to see how they are getting on with it , i asked how they were getting on with it as they said they were looking at it today and i never had chance to phone them , as i work in a very low signal area !!!
not at 7 o clock it wouldn't no i dont really enjoy listening to a ringing tone knowing the phone isnt going to get answered , as they are only open till 5 :S
  A SHED!
... um think you are all missing the vital point here...
The car is not working due to anything to do with us, we are fixing it for him FOC...
We have had the likes of Danny on here who is a well known and respected clio specialist, who foind the cam timing to be WAY out and then upon correcting it the car loses power. Something is wrong with the car beyopnd our control. Nick understands this, and is happy with the service we have provided.
I think you should remove your itbs etc and let the poor lad go to k-tec with the money he's paid you. His car should be your top priority in getting running it right, youve fobbed him off for 3 months with excuses.
sounds good to me , if it isn't running around the 200 when it comes out of there i think thats what i would want to do ,
Ive fobbed him off for 3 months with excuses? So far I have recitifed bad cam timing, and now remapping the entire thing for free.
After having a look at it today, I am starting compeltly from scratch with the map down to inital timing offsets etc. Have been using a basemap for one i carried out on a similar (172) car and I think a clean slate is what the car needs.
Updates to follow... either way its now in the pre-mapping bay so its the next one to be done....
Status
