Yeah sure
@jefinabox ,
http://www.demon-tweeks.co.uk/motorsport/harnesses/sabelt-3-point-double-release-harness is the same harness as what I use. They are bolted into factory positions so you know they are suitable for the loads if the worst was to happen.
I did Blyton last week and to my pleasure my cheap alloy wheels didn't explode like some thought they would, first thing was to try and find a starting point for the tyre pressures. I'd read on here that you had to run them at quite a high pressure otherwise the sidewall could end up with excessive wear and fall to bits. Initially I had it at mid to high 30s and the car just wasn't happy and just seemed to bounce about everywhere.
After speaking to a friend with a 106, he recommended I try around 26psi cold in the tyres and take it from there with running a couple of PSI less in the rear tyres too. Needless to say I gave it a shot, first few laps were a bit wobbly but once the heat got into the tyres the difference was amazing. By the end of they day my tyres looked something like this
Federal RSR by
Simon_89, on Flickr
It was a great day and met a few people too off the forum.
Gave the car a much needed wash after last weekend, the wheels were filthy from brake dust and I even found a few bit of rubber stuck to the inside of the alloys too!
Dirty Alloys by
Simon_89, on Flickr
Whilst I had the alloys off for cleaning I was checking the tread to make sure there wasn't any damage and found a stone embedded into the tyre, I removed it and it had lodged itself in quite deep. There's also still signs of the tyre melting, I thought this would of warn away by now or when it was all coming off down the M180 and hitting my back bumper!
Stone in tyre by
Simon_89, on Flickr
Grainy Tyre by
Simon_89, on Flickr
Melted Tyre by
Simon_89, on Flickr
and finally one of the car cleaned, not bad for a daily track car that turned over 109k on track last week!
Clean Car by
Simon_89, on Flickr
