Ffs!!! New Graphics Card Help
Ant1
Brembo! Brembo! Brembo!
Just purchased one of these
http://www.microdirect.co.uk/(16579)INNO3D-GeForce-8800-GTS-320MB-DDR3-PCIE-HDTV.aspx
Arrived today so tonight i have installed it. Switched the pc on, all seemed ok, loaded windows, all ok. Installed software, rebooted the pc, now all it goes to the windows is loading screen where the progress bar is moving, gets past that point and than nothing. Blank screen. The only way o can get this card to work is either not to install it or run the pc in safe mode.
Haven't got a clue what to do so has anybody got any ideas before i have a major paddy?
  Turbo'd MX-5 MK4
uninstall the driver in safe mode then retry? or check the manufacturer's website for a newer/different versioned driver?
Ant1
Been there done that. Only thing that i have learned within the last 10mins is.
1st. If i let windows install the driver it comes up with a error at the end saying access denied which is stored in the graphics card tap under systems.
2nd. Downloaded drivers from website and when it's complete it says " Installion not complete"
3rd. If i use the cd, during installation it flickers the screen for a few secs which is normal than it goes blank.
BO**OX
JMR
  RB 182 Cup
Have you got onboard graphics to start with?
If so have you disabled it in the BIOS?
ps.. You still interested in that K750i mobile Ant?
Ant1
No onboard graphics.
Sorry bud got a upgrade. Meant to drop you a pm :eek:
Anybody??
Darren S
The access denied bit sounds a bit weird. I take it that you've got full admin rights over your PC? You haven't got any restricted accounts on there, have you?
Did you use the CD for software installation? I never, ever use the CD within the packaging - unless its for something very specific. By the time the card lands in your mitts, it's several versions out of date.
Here's the latest for the 8800 series:-
http://www.nvidia.co.uk/object/winxp_2k_97.92_uk.html
..... assuming your using XP 32-bit?
What card was you using before? Make/model?
D.
R
rich[182]
I'd put your original card back in then boot into XP
Update latest BIOS and motherbaord chipset drivers if there not upto date
Download latest graphics drivers
Install Drivercleaner and remove all your old graphics card drivers
Then run regclean and regcleaner
Shutdown
Install new card, boot into XP cancel at all prompts for drivers and then install latest downloaded drivers then install latest DirectX9 february update too
Ant1
is says on the box
400 low sli mode
450 medium sli mode (my psu is 450)
500 high sli mode.
So theory yes.
Ant1
Has anbody got a pic of a 6 pin power cable running from the psu which powers the graphics card?
The reason i ask is that i have connected 2 standard power supplys to the graphics card addaptor that you would use for a hard disc/cd rom.
Is this the correct connectors or are there a special express power cable which a psu comes with?
  Turbo'd MX-5 MK4
yep, i've built my new system today and it has 2 x seperate 6 pin PCI-E power connections from the PSU going into it.
  Turbo'd MX-5 MK4
the graphics card has two of these on it :
and the cable connections look like this :
hope this helps.
  Turbo'd MX-5 MK4
i'd imagine your supposed to connect the molex (white connections) to your PSU and then the black 6 pin connector into the graphics card.
Ant1
Hmmm
that's what i have been using. Trying to think if it's worth buying another psu to be sure.
random thought but you never mentioned anywhere that you uninstalled your old graphics card drivers.
THe 8800 series is picky with what drivers it uses and having old ones still present will prevent new/different ones being installed.
Also check you bios to make sure the defualt graphics is PCI-E
Ant1
Yeah done all the above. When i install the new drivers it gets to the bit where it flickers the screen off and on 3 times. 3rd time it stays off. After a reboot it's fine upto it goes past the part with the windows loading progress bar than goes blank. GRRRRRRRRRRRRRRRRRRRR
Ant1
Maybe. I will be sending it back!
Thanks for your help matey :star:
Ant1
Just tested this on my mates machine and it works!!!!
Swopped over myhard drive on to his also and is A OK.
This now points to the motherboard! Just making sure everything is uptodate before i decide to buy another.
If i have to puchase another board does anybody have any recommendations? Needs to be Intel dual core compat.
