Register a free account today to become a member! Once signed in, you'll be able to participate on this site by adding your own topics and posts, as well as connect with other members through your own private inbox!
Mines runs from battery to a mega fuse then to the kill switch then to a junction box in the engine bay. It's also wired in to the ignition to kill that when switched.
You need to cut power to the ignition/coil when it's turned off.
Also you need to wire a resistor to ground from the alternator side when the switch is turned off to protect the alternator. Needs to be a high power low ohm resistor like a 3 ohm 11w as pictured.
