Fitted my H.I.Ds
  e92 330i
Ok got round to fitting my hid set, got them from hids4u.co.uk and the quality seems really good! Now I thought I'd do a little walk through. The kit I bought is the h7r reflector so they hopefully won't blind anyone.
Right firstly remove your front bumper, it's only 6 screws and makes the job 10000% easier! 2 screws under the arch and one underneath near the splitter. You can either unclip the grill or take out 2 more screws, I just took it off too.
Now take put your headlamp, 3 more screws and unclip the electrics. Now ypu want to take out your old bulb, it just pulls off the clip like so.
As you can see above you'll need to fix that metal peice onto your shiny new bulb, but as the bulb has wires coming out I had to cut a gap to be able to put it around the base of the bulb
This took awhile as I did it by hand
10mins later.....
Eventually got through and popped it on the back of the bulb
Now you need to pop a 25mm hole on the back rubber and pass the bulb and grommet through, I did this with a 25mm gasket punch, but you can do it with what you like.
So now it should look this this and with the metal clip on the back of the bulb, the hid kit is simple to connect it's just male to female, you can't go wrong!
This was the tricky part trying to get the bulb in place and the best reason to why you need the lamps out, I held my fingers on the sticky out bits and held down and twist, took a few attempts but it goes in!
Now the two spades just push into the black "thing" pictured below, it used to hold the bulb in, yellow to red, black to brown simples.
Now just push this inside like so...
And put the cap on pulling the grommet through
And you done! Nearly. Put the headlamp back and connect up the wires again trial fit with one screw and turn your lights on, if you fitted it all back and it didn't work you've only got yourself to blame :) find a home for the ballast and if the bulbs flicker at the start that's fine.. Apparently. Takes around 2 hours all in all and here's the final result
Well it's still daylight!
  e92 330i
Good effort. Wheels next.
What temperature did you go for?
Cheers, opps forgot to mention went for 6000k, fancied the 8000k but says it gives alot less light. Also the hid kit seems a little lower then previous, in about 1m distance looses about 1" in hight, not sure if this is right?
8000k are illegal.
Not sure how illegal yours are tbh. as youve got the reflective one im abit unsure.
Got myself a set of sport xenons fitted last week and they are a massive improvement even with 4300k bulbs. 6000k coming next couple of days :)
ForceIndia
  Gentlemans spec 200
Sorry, but xenons etc in standard reflector is retarded. Totally unsuitable set-up, guaranteed to dazzle oncoming roadusers. Reflector units designed for halogen should never be used for xenons!
Go out for a drive with your headlights at #0 on the headlight adjuster beside the steering wheel and see if you get any flashes from anyone.
I have the H7 bulbs, not the reflector ones and I was getting flashed constantly so I put it down to #2 on the adjuster and it solved it, although I'd maybe look into getting the H7R bulbs if they are better.
  E36 Coupe & Mk4 Golf
Fitted mine last night. i cut the wires then placed the metal holder over the top. I mounted a ballast on the osf inner wing and the nsf on battery casing.
When parked up look at then angle of the beam against a wall. if its at a steep angle going up your going to dazel people. I put standard sport xenons on mine and at 0 they aim really high and knew this straight away from the beam angle so rolled it down to 3/4.
  S4 Avant
fitted mine too last night, also went for the hids4u 6000k kit, except had h1 bulbs, doddle to fit like you said
8000K are not as bad as people make out imo, providing they are set up correctly.
  e92 330i
Tbh I don't care as long as they pass an MOT I'm happy, they're lower then the halogens by quite abit and been for a drive after 20 mins no flashes :) they look good tbh, the reflector ones seem to cover the bottom half of the bulb, I'm guessing this stops the light bouncing off the bottom reflecting housing and no light goes up?
  RB 182
Bought the exact same set wen i had my Leon, with the reflectors but i complained to HIDS4U as if you put them on a headlight beam tester (as you should do to make sure they're set up properly), the beam pattern is still all over the place! Couldn't find a definate kick up which it says you will, and the light output was terrible!
ForceIndia
  Gentlemans spec 200
Exactly. Reflectors work in a completely different way to projectors. Reflectors made specifically for xenons work (I think Volvo used to use these) but standard reflectors don't work. Anyone that says they do, is an idiot!
Worst of all, it looks very chav imo. Set of projector lamps for the Clio isn't exactly expensive, if you can't afford to do it right, don't do it.
  e92 330i
I like them, doesn't look "chav" IMO and it's my car, But thanks for your opinion I won't be taking any notice :D
+1
Its like people who buy 3/4 front plates and know they are illegal but they don't get hounded for it like we do for fitting HIDs. (And no I don't intentionally blind people, hence why I have mine moved down on the headlight adjusters, I merely have them because they produce better light for me to see)
  e92 330i
Indeed, I paid an extra tenner for the h7r so it would prevent blinding, tbh I don't want to spend an extra £200 on headlamps when I'm not harming anybody
  S4 Avant
Its like people who buy 3/4 front plates and know they are illegal but they don't get hounded for it like we do for fitting HIDs. (And no I don't intentionally blind people, hence why I have mine moved down on the headlight adjusters, I merely have them because they produce better light for me to see)[/QUOTE]
+1
ForceIndia
  Gentlemans spec 200
You guys can talk about adjusting all you want, but it's nonsense. You fundamentally do not understand how reflector technology works. You can not adjust them to stop dazzle, utter nonsense.
Christopher
  Z4M
I didn't realise they weren't installed into projectors. Should've seen that!
Yeah, 100% illegal and they look uber pikey.
+1
Pretty sure my 3/4 plate has never dazzled another driver or affected their vision. Can't be certain though.
Fitting HID's is fine if your lights can accommodate them. Non-xenon lights can't.
