fitting camber shims
I dont know if the methods of doing this are much different between sport/nonsport
if they arent or are, does anyone have a guide/instructions how to fit camber shims
what tools and how hard the job is etc
cheers :cool:
GrahamS
there is no difference
Take off the drum
unbolt the stubaxle from the beam. Spacer/shim in. Reassemble and tighten hub to 175nm
Can't remember the size of the torx bits but make sure you have good quality tools as they will be tough to undo. Clean the exposed thread on the otherside before removing.
It's an easy job if you are patient.
Take off the drum
Cheers,
I've got the torx heads and spanners
How hard is the drum to remove?
  Focus st170
I've put shims on my clio with drums it's easy. Jack the car up take off the wheel. Then just undo the 4 bolts on the back of the drum (don't drop the drum when undone) then put the shim between the rear beam and drum and tighten back up. You don't have to take the drum apart or anything.
