fitting doorcards mk2 ph2 HELP!
Car  Chocolate Bar™
I'm trying to fit my new interior, everything was going swimmingly till i tried to get my rear door cards off. How the hell do you get them over the bar at the base, where your seat belt attaches? Cant see how you can remove it, and it wont feed through. any help greatly appreciated :)
Mark
This isn't directly clio related but....
In the cases where I have done this before,
one end of the bar is fixed down by a bolt/other!
You undo this end and then the other is just a case of fiddling with the bar until it comes through the hole,
the bar normally has an 'S' shaped kink in it which locates it in the hole!
Hope this helps!
thanks mate, managed to get them off now with a bit or brut force! have tried the fronts yet tho and they're meant to be harder :S
did you get the bar out? the theres a bit of a knack to it, I had to look at the spare ones I had and work out how to turn and release them from the body.
front door cards are a piece of piss, pm if you need any info!
front door cards were worse than the rears! couldnt get any of the clips/holes to line up straight. I almost ended up binning em i was so frustrated :banghead: got the passengers side in (just) but still working on drivers, looking good though. Thanks for the advice everyone :)
