fitting front spot lights
Car  1.5 Clio Dynamique
im thinking about fitting front spot light to my 1.2 grande (no fogs as standard) how easy would this be as i was thinking off putting it in with the same circuit as the headlight so as the headlight come on so will the spot lights
they wont be bright they will just be there for looks?
should i wire them this way or is there a easy / better way to do this and does anyone have any tips?
dont, lol
if you wire them up to come on with your headlights,
youll get pulled and £30 fine,
perhaps wire them to come on with your beams,
but thats about it,
run a wire from your beams to a solenoid, and a fused wire from the battery,
still pointless as fogs throw a wide spread amount of light over a short distance,
so youll be lighting up the gutter 2metres in front of you,
though i did put some in my 1.2, because they look loads better than blanking plates
get fogs instead, i think the wireing loom is already there fogs just need putting in
I was looking to put a set of fogs on my old 1.2 but couldnt find a set so in the end i bought the surrounds. Then bought some angel eye fogs and used the loom in there, they wire up so with your sidelights the halo comes on, then you can either have the fog wired to your dipped beam or main beam as you get a control box to turn then on or off seperate, but i ired them to my main beam so when i flashed someone they would come on too :)
