Preliminary guide to fitting matched inlets, will have to add photos when I get home tonight
Guide to fitting matched inlets on a 172 ph1
Tools:
set of sockets, 2 extensions, 1 universal joint,
set of spanners
penumatic jack
vacuum cleaner
kitchen tissue paper
useful: magnetic dish to hold bolts and nuts, magnet on extendable stick to reach for stuff that you drop
1. Undo 4x torx screws holding down engine cover, remove engine cover
2. Unplug sensor on the left of the plenum
3. Unplug sensor on the right of the plenum
4. Unplug breether pipe coming from elbow to back of plenum
5. Unplug pipe going from throttle body to back of plenum
6. Unplug vacuum pipe on back of plenum
7. Unclip the wire going to throttle body
8. Unclip the coilpack connections, 4 HT leads and 1 from wire loom
9. Unclip the wire going to the breether pipe connector at the back of plenum
10. Undo 4x 10mm bolts holding down the coilpack, put coilpack aside
11. Undo 4x torx screws holding throttle body in place, put throttle body aside
12. Undo 2x 10mm bolts besides the coilpack mount holding down the plenum
13. Undo 5x 10mm bolts holding down the plenum on the front
14. Check nothing is connected any more. Remove plenum
15. Undo 2x 10mm nuts inside fuel rail guard. An extension will be needed for the socket
16. Remove fuel rail guard
17. Unclip wires going to injectors
18. Undo the 3 small (10mm?) bolts holding down the fuel rail
19. If you can, pull out fuel rail and injectors - can be wedged in quite tight. If not remove them once you've removed the lower inlet.
20. Change your spark plugs and leads if needed at this point. Main thing is not to overtorque the spark plugs. Use some copper grease on the spark plugs' threads to make future removal easier
21. Using a spanner, undo the 2 shafts that the fuel rail guard was attached to
22. Using socket + extension, it should be possible to remove 7-8 out of the 10 large (14mm?) bolts at the front of the lower inlet
23. Using socket + extension + universal joint, it should be possible to remove the remaining 2-3 hidden (14mm?) bolts at the front of the lower inlet. Likely to get cut knuckles during these 2 steps
24. Optional - undo bolts holding in the plastic underbody cover, remove underbody cover
25. CAREFULLY place pneumatic jack under sump (I placed it not far from sump hole), support the engine using jack and use some padding material to protect sump
26. Remove engine mount, be careful as the engine will sag and need support from the pneumatic jack. 3x large (16mm?) bolts on the engine and 4x large (16mm?) bolts on the car
27. Jack up the engine some more until the last bolt on the left side can be removed with socket + extension + universal joint
28. Loosen AC bracket bolt, but not remove, just loosen enough to make it clamp down less on the lower inlet
29. Once you're sure you removed all the bolts (check against matched lower inlet for where all the bolts are), start trying to remove the lower inlet.
30. If the inlet will move to the right, some slight tapping from a hammer can be used to help remove the lower inlet and gasket
31. Vacuum the 4 holes on the engine block - you'll find some dirt was dislodge during removal of the lower inlet
32. Plug up the holes with some tissue paper so no more dirt gets in Clean the area around the 4 holes with a wirebrush
33. Remove the tissue paper, vacuum the holes again and clean with some wet tissue
34. Clean the mating surfaces of the matched inlets with wirebrush, vacuum and clean
35. Plug the injectors + fuel rail into the new lower inlets
36. Assemble the bolts for the lower inlet, there should be 4 short ones for the bottom, 1 slightly longer for left side of bottom, 2 long ones for the top, 1 longer one for left side of top, 2 very long shafts where the fuel rail guard will be mounted, and one fat one for the left side at 90 degrees to all other bolts
37. Carefully fit gasket and lower inlet. I used 2 bolts to line up the inlet and gasket, then carefully lined it up with the engine
38. Get the bolts in one by one, make sure you don't tighten any of them until you have all bolts in, otherwise you'll have a slight mis alignment and the last bolt will refuse to go in and you'll have to slightly loosen them all again.
39. Tighten the bolts, bolt the engine mount back. Lower jack
40. Tighten the AC bracket bolt on the engine block again
41. MAKE SURE THE HT LEADS WON'T BE CRUSHED BY THE PLENUM. There is a gap on the plenum for the HT leads to pass through, if you don't make sure the leads pass through the gap (like I did), you will clamp down on them with the plenum and destroy them.
42. If you have matched upper inlet plenum as well, switch the large O ring from the bottom of the one you took off onto the new one. You'll also need to remove the breather pipe connector thing from the back of the old plenum and fit it onto the new one
44. Mount the (new) inlet plenum. MAKE SURE NOT TO CRUSH THE HT LEADS. 5x 10mm bolts on the front, 2x 10mm bolts at the back
45. Clean all the gunk from the throttle body at this point.
46. Remount everything: throttle body with 4x torx screws, plug in sensor on left of plenum, plug in sensor on right, breather pipe from elbow, vacuum pipe at back of plenum, pipe from throttle body to back of plenum, wire connectors to throttle body, connector to breather pipe connector, connectors to injectors
47. Recheck everything, start engine
48. If everything is ok, put the fuel rail guard and engine cover back
