Fitting silicon hoses - hard or not
Evening
Before i order the hoses next week... will these be a pain to fit, do i need to drain any liquid or anything b4 disconnecting existing pipes?
someone enlighten me on the task ahead.
James
*I should be a member tonight!!!!* :D
if your replacing the coolant hoses, then obviously i would advise draining the coolant system first
as easy as fitting std hoses.
and draining and refilling aint hard......
just take off the std ones and put the same looking ones back in the same place......done......oh and refill with water.
