J James20VT Oct 18, 2002 #1 Evening Before i order the hoses next week... will these be a pain to fit, do i need to drain any liquid or anything b4 disconnecting existing pipes? someone enlighten me on the task ahead. Cheers James *I should be a member tonight!!!!*
B BRUN Car Skoda Fabia vRS Oct 18, 2002 #2 if your replacing the coolant hoses, then obviously i would advise draining the coolant system first
BenR Oct 18, 2002 #4 as easy as fitting std hoses. and draining and refilling aint hard...... just take off the std ones and put the same looking ones back in the same place......done......oh and refill with water.
J James20VT Oct 18, 2002 #5 ah, if its just water, then soundo k ill give it ago myself, suppose u dont learn anything unless u try it urself.
B BRUN Car Skoda Fabia vRS Oct 18, 2002 #6 water yes, but you do need a fair amount of coolant in there too
