flash 8 and text help
Andy_con
Car  clio 182
using flash 8 which ive never used before, how do i make the text white with a blue outline?
there seems to be no outline option?
just been reading that but cant get the ink tool to work.
just need to learn how the breka the tx apart
1. With the text selected, hit CTRL+B which should make the text into a graphic.
2. Deselect
3. Select the outline tool from the main toolbox
4. Select the outline colour and other properties
5. Click on the letters one by one
Im failing big time here!
ctrl+b bit done
outline tool? there isnt one?
Can't you just select the outline and change its colour?
Sorry I can't be more helpful but I don't know too much about Flash 8.
Can't you just do it in Photoshop using stroke and then import it to Flash?
thats the most annoying thing there is no outline option grrr...
i dont own photoshop, ill sort something out dont worry. thanks for ya help
Try GIMP, it's free.
I would suggest asking on a Flash forum as you'd get much better advice.
