Flat Battery - Head Unit Issue?
Car  Clio Trophy
Been looking after my mates 03 plate 1.2 (mk2, ph2) while she's been away on holiday but the battery has gone flat...
We've jumped started the car and got a bit of charge back into the battery, but the radio will not turn off (ie, car is running but pressing the power button on the radio doesn't turn it off). She's also mentioned that the radio has played up before.
Looking at the wiring diagram for the car, it seems as if the radio has a permenant 12v feed from the battery, and gets a signal from the ignition switch to turn the unit on/off when starting/stopping the car so it is conceivable that the unit could be powered up with the ignition off if there is a fault in the unit. Does anyone know if this is a known problem with the stock cd/radio unit or have any other suggestions what the problem might be?
Thanks!
take the radio out of the car, till she gets back and then suggest an aftermarket one.
have you tied holding the power button dwn as most head units u need to do thatif not change the live cable there is all ways 2 usally red & yellow just swap them ova then head unit will work with out the keys and it will trun off
Well, the radio has been out of the car since sunday and the battery is still fine which suggests to me the fault is in the unit itself.
Blaze - tried holding the power button down on sunday but it didn't make any difference, it normally only needs a touch anyway.
Fred - Sent you a PM on ClioTrophy about the radio & also brake pads.
thanks for the suggestions!
