Foam Lance Info
Car  RB 182
Just got my lance and snow foam from cleanyourcar. I've read up on dilution rates etc and thats seems pretty straight forward. What I am stuck with is what does the +- dial do on it and how do i know when it need adjusting? cheers for any help on what prob is a pretty straight forward thing.
that dial if its the same as mine is just the amount of foam you want, more you use the less time the solution will last etc.
to be honest i just "use a dribble of this, fire some water on and squirt" does no harm!
Obviously it depends how dirty your car is, having a weak mixture wont lift the dirt aswell as a thick mixture.
Having a weak mixture is all well and good if you keep your car clean everyday, but if you don't clean it everyday with this weather a weak mixture wont work as well.
the more towards the "-" you turn it the more foam you use but its proper foamy.
the more towards the "+" you turn it the less foam you use but its not very foamy :)
