Formula Renault Engine
  Williams Clio
Bit of a random one this but im trying to help a college get a 1991 Formula Renault up and running for next season.
The guy who is leading the project is looking to a fit a 2.0ltr engine to it before the end of this year. Currently there is a 1.7ltr engine, which im guessing was originally fitted the Renault 21, which is mated to a Hewland gearbox (think its a H4)
Does anyone know is the F4R or F7R Renault engines will fit onto the Hewland with the current adaptor plate or is the 1.7ltr engine going to have a different mounting pattern?
I'm also guessing that an new ECU, loom, exhaust and intake manifold and dry sump kit will be required.
Any help would me much apreciated.
Jason_E
  Too many.
Sorry to jack this thread. But you wouldn't happen to go to the Bicester campus would you? ;)
M
mini-valver
Im pretty sure the Hewland will fit onto an F series block, All the 5 speed Renault boxes are interchangeable AFAIK. Well, they all bolt up right, starter positions can change though.
  Williams Clio
Oh an as Chris has already pointed out i don't have anything to do with the Bicester campus used to live not far from there though.
as long as the block was bolted to a J series gearbox.. I don't think the newer blocks have the right holes.
I know a guy who fitted a megane engine into one a few years back.
M
mini-valver
Think its just 6 speed boxes where the bellhousing differ. Pretty sure ALL 5 speed box's and bottom ends mated to a 5 speed as standard have the same stud pattern. Could be wrong though!
