Just thought of something else!
Try the brilliant WD40 which has hundreds of uses, one of which is that it DISSOLVES GLUE!
CLEANS: WD-40 gets under dirt, marks and grease making it easy to wipe away. It also dissolves adhesives, allowing easy removal of labels, tape, and stickers.
DISPLACES MOISTURE: Because WD-40 displaces moisture, it quickly dries out electrical systems to eliminate moisture-induced short circuits. Turn the power off before you spray
PENETRATES: WD-40 loosens rust-to-metal bonds and frees stuck, frozen or rusted metal parts.
LUBRICATES: WD-40s lubricating ingredients are widely dispersed and hold firmly to all moving parts.
PROTECTS: WD-40 protects metal surfaces with corrosion-resistant ingredients to shield against moisture and other corrosive elements.
